#127379 06/10/01 06:36 PM
cinkerf Offline OP
A Concrete cutting saw has a dual voltage rated motor. Nameplate values: 120/230V. 28/14A. 1Ph. 3H.P. The building voltage system is: 120/208V. 3Ph. 4Wire. For this job we do not want to install a boost transformer necessary to supply 230 volts to the motor. We are just going to supply the motor with 120 volts. Is my drawing compliant with the Code? http://www.geocities.com/cinkerf/saw.html
#127380 06/10/01 06:43 PM
Anonymous
Unregistered
This thread is running at three places.
I suggest that anyone replying should reply at either:
http://www.mikeholt.com/forum/Forum1/HTML/000663.html
or
https://www.electrical-contractor.net/ubb/Forum2/HTML/000181.html
to concentrate replies at fewer places.
