0 members (), 376 guests, and 7 robots.
#127113 04/29/01 06:55 PM
Submitted by Ken Mendelson
How does this amplify the signal if there is no external power or batteries?
Radio Shack part #16-1156
Thanks
Ken Mendelson (KEMendelson)
#127114 04/29/01 06:57 PM
using the 'force' ?
#127115 04/29/01 08:59 PM
I was wondering the same thing with pole mounted CATV amplifiers... Where do they draw their power to boost?
-Virgil
5 Star Inspections
Member IAEI
#127116 04/30/01 01:04 AM
Kind of depends on the system used.
CATV systems will have some DC coupled to each loop, which is to drive line amps at nodes, so they could also use that DC to power a small in-line preamp, such as the one pictured.
DSB [Satellite broadcast] will drive the LNB / LNBF at the "Dish" receiving antenna with DC power, which is coupled to the coax feed [the cable coming from the dish].
As to regular Yagi / Parasitic Yagi antennas used for VHF / UHF television, these two types of preamps can be used - without external power source / coupled DC:
1: Cable Bootstrapping [via Op-Amp LH2011].
This reduces cable Capacitance, leakage and spurious voltages. Stability is increased with a small Capacitor connected at the input.
2: Wideband Unity Gain Inverting Amplifier.
This one compensates for the normal 6dB loss on 75 ohm coax runs. The one pictured above in the posted image states 13dB amplification, which sounds like this type of Inverting Amp.
13dB would be lossed over 3 RF inputs [3 TV sets], run through a "4 way splitter", more if two "3 way splitters" were used.
Judging from the frequencies listed on that amp, it would be used on high frequency CATV [capable of Analog with compressed Digital services], but more likely for a DSB type system.
950 - 2050 MHz is the bandwith of my DSB feed, however, I have noticed some newer CATV with Compressed Digital feed had this bandwith listed on the receiver.
Scott SET
