1 members (Scott35), 131 guests, and 8 robots.
#124559 10/15/06 02:55 PM
This light is located but a few doors from my home. I wonder how long it will work, until the wires wear through? And- how long will it take the handyman to find the reason the breaker keeps tripping?
#124560 10/15/06 10:09 PM
Well, if the breaker is of "Zinsconian origin", just follow the shower of sparks [Linked Image]
Probably would guess a few weeks of swaying in the wind and the conductors will ground out.
#124561 10/16/06 11:58 AM
Just dropoff your card. Im sure you will get a call in a couple of weeks at best. Hopefully the conduit is properley connected or else there may be a chance of energizeing the pipe,
#124562 10/16/06 01:37 PM
Is it just me, or does this mess look like it has been painted WHILE dangling like that?
Either that, or we can only see the neutral wire...
#124563 10/16/06 08:14 PM
Good catch, NJ! While the light may be playing a trick, I just looked... and you are probably right!
#124564 11/13/06 12:15 AM
An update.... this fixture was out...but now has a new bulb in it. That someone would change the bulb without fixing the problem amazes me!
#124565 11/13/06 12:32 AM
Why bother to even change the bulb? It looks like it was supposed to light up the wall, but it's not quite doing the job. Reno: is this located in the southwest? (just wondering what kind of weather it's exposed to)
[This message has been edited by PEdoubleNIZZLE (edited 11-12-2006).]
