1 members (Scott35), 151 guests, and 9 robots.
#123194 03/06/06 11:36 PM
Thought the gang would like this
- DAVE TAU
#123195 03/07/06 12:40 AM
Was that mouse rated for use in that box?
#123196 03/07/06 01:38 AM
That mouse looks to be on the neutral side of that outlet. Was it wired correctly? The mouse should have tested it before getting in there.....
#123197 03/07/06 07:21 AM
Is he rare, medium or well done?
#123198 03/07/06 08:33 AM
Build a better mouse trap and the world will beat a path to your door!
Dave
#123199 03/07/06 10:38 AM
Another reason for using wall plates...to keep the beasties out (or in, in some cases) [Linked Image].
wa2ise: Agreed. He should have tested before entering. I thought that's what the whiskers were for [Linked Image].
#123200 03/07/06 01:12 PM
If you'll look closely just above the dultlex inside the box, what do you see? The look at what's just above the top of the outside of the box.
Did the kids loose a mom or dad?
#123201 03/07/06 02:10 PM
After mousing in a cable I always take the mouse out before installing the receptacle due to the room constraints. Conversely, it looks like they only did a box fill for the front half of the mouse but tried it anyway.
#123202 03/07/06 06:55 PM
Actually its a trained mouse.. can slip behind the receptacle and check those pesky " push in " connections... You don't even have to remove the device anymore!!
Isnt Technology grand?!!!
#123203 03/07/06 08:43 PM
Is each mouse counted as 2.0 cubic inches or are they cumulative?
