1 members (Scott35), 455 guests, and 10 robots.
#123102 02/28/06 11:20 PM
I guess the guy who did this just didn't have quite the right parts in his toolbelt.
- renosteinke
#123103 03/01/06 05:39 AM
probably an emergency service call to get the dang thing up and running.
#123104 03/01/06 05:58 PM
Apparently he didn't have the correct length of liquid-tight either, also one part looks alot newer then the other. what this looks like to me is that the shorter piece of flex, the one that goes to that ell fed some original piece of equiptment directly, then that piece was removed and that swamp cooler was put in, and required a longer length of flex, so they put in a new piece using that horrible looking thing in the middle. This install could be improved drastically merely by putting that ell on the swamp cooler, and attaching that TA that's currently on the cooler to the other end of that coupling... it's so counter-intuitive it's like someone actually had to put work into making this look uglier then need be.
#123105 03/01/06 07:18 PM
I wonder if this hack even bothered to run new wires or if there are some wire nuts crammed in there.
[This message has been edited by napervillesoundtech (edited 03-01-2006).]
#123106 03/01/06 10:11 PM
My money's on wirenuts crammed in there.
And welcome aboard, napervillesoundtech!
Tony, L.A. cinema tech [Linked Image]
Stupid should be painful.
#123107 03/01/06 11:44 PM
Wirenuts wouldn't fit...you have to use butt splices.
#123108 03/01/06 11:44 PM
#123109 03/02/06 11:03 AM
It amazes me how much work someone will go through to do something wrong. It wouldn't have been that hard to install a new peice of flex. [Linked Image]
edited for spelling
[This message has been edited by napervillesoundtech (edited 03-02-2006).]
