I need to find an instrument to monitor and record the output of a 24vdc power supply for a continuos period of 10 hours or more. I need something that will capture everything down to a voltage drop or spike with a duration as as little as a split second. Is there something available out there for a price of say $400 or less? I don't care if I need to link it to a computer to make it work.
Does anyone have any experiance with these instruments? Will they detect something as minimal as a "flutter" in the voltage? Is it capable of capturing data this sensitive for several hours solid, preferably up to 10 hours? Thanks
The people over at EXTECH should be able to answer any questions you may have about this particular equipment and it's applications. That's a direct # to their tech dept.
