For the record, the top photo has been flipped 90 deg. when it was transplanted here. The fuses are horizontal, but that has never made a differance in any piece of equipment I've ever worked on. I may keep these and experiment on the fuse when I get the time. If this failure could be detected early with an ohm meter it might just pay to do a little preventative checking. Let see 71 airhandlers 9 fuses each....639 fuses over 1001 square feet of roof. If you don't factor in the fire alarms, much less trouble to just let'em toast! (just kidding)
