1 members (Scott35), 128 guests, and 11 robots.
#122167 10/02/05 12:45 AM
The gutter shown in this pic contains the main feed to a number of panels at a shopping center. Some extra holes were filled with.....some interesting 'plugs.' Anyone know what they were really intended to be used for?
- renosteinke
[This message has been edited by Webmaster (edited 10-02-2005).]
#122168 10/02/05 01:26 AM
They look like the plugs plumbers use to seal lines for pressure/standing water testing.....
Someone got creative.... [Linked Image]
Stupid should be painful.
#122169 10/02/05 11:41 AM
What an electrician that did not have any 4" square blanks?
Anyway I will go with slicks thought or maybe plugs to be used when heating PVC for bending?
#122170 10/02/05 11:43 AM
By the way I would also say they where punched out for either pulling or feeding the wires in the opposite pipes.
The folded one also.
#122171 10/02/05 06:39 PM
tkb Offline
These are T&B Push-Penny® Plugs.
I thought they were for plugging conduits. I never saw them used as KO blanks.
Plug, Conduit, Connectors (Push Penny® Plugs)
Economically seal out grout and plaster from
any fitting or raceway conforming to CSA
dimensional tolerances. Made of flexible plastic,
they push into place and are held fast by
pressure against internal surface of fitting or
raceway. Eliminates need for separate capped
bushing or steel penny and bushing.
Application
[*] To plug open end of conduit or connector
in order to prevent ingress of
trash, dirt or moisture during construction
and remodeling.
Features
[*] Wide range of application; can be
used with rigid metal conduit, intermediate
metal conduit, electrical
metallic tubing, all connnectors and
all bushings.
[*] Designed to stand up to normal
handling and is functionally unaffected
by moisture.
Standard Material
Polyethylene
Standard Finish
As molded
Listed/Certified by:
CSA (LR2884, LR4484)
Conforms to:
U.L. 514B
CSA C22.2 No. 18
NFPA 70-1999 (ANSI)
NEMA FB1
Push-Penny® Plugs
Cat# Size
1470 1/2"
1471 3/4"
1472 1"
1473 1-1/4"
1474 1-1/2"
1475 2"
1476* 2-1/2"
1477* 3"
1478* 3-1/2"
1479* 4"
* Not CSA Certified
CSA File No. 2884
UL not applicable
[This message has been edited by tkb (edited 10-02-2005).]
#122172 10/03/05 11:43 AM
I wonder how many younger electricians would know what a "penny" is when used in electrical context?
Larry LeVoir
Inspector
City of Irvine, CA
#122173 10/03/05 03:46 PM
it's easy, a penny is a high current fuse link that is usually protected by the wiring in case of a fault
JFW
#122174 10/03/05 07:54 PM
"The penny" has been replaced by "The ductape" in the minds of younger guys I think, Larry.
