by NORCAL - 03/19/24 05:11 PM
0 members (), 265 guests, and 15 robots.
#121924 09/01/05 03:59 PM
I thought this was interesting. It is in a bathroom of a vacation cottage we were at. Has anyone seen this before. It solves the problem of where to put the required outlet. The glass mirror has an opening in it for the gfci receptacle.
electricman2
#121925 09/01/05 04:57 PM
I see this everyday in my city.
If you are installing them, you want to use an extension ring. The covers break very easily if they are not perfectly installed.
Ryan Jackson,
Salt Lake City
#121926 09/01/05 06:03 PM
So do the mirrors [Linked Image] You can guess how I know that.
#121927 09/02/05 02:04 AM
Thanks for the picture e-man2!. [Linked Image]
Is that plate stainless steel?.
Only thing that would concern me about this, would be wether there has ben some sort of sealing around the back of the GFCI plate to prevent moisture getting into the recept.
Or is this mirror equipped with one of those mirror demisters?.
One of the local FF's here is a glazier and he said he hates working with mirrors, you have to use special glue to hold them to the wall.
He also mentioned he has built up about 600 years of bad luck, if you are superstititously-inclined.
Shame on you Tony. [Linked Image]
#121928 09/02/05 02:40 PM
I guess the plate is mirrored glass too... guess they're _not_ cheap...
#121929 09/02/05 02:43 PM
Yes the plate is SS and I wasn't about to remove it to look further and take a chance on blowing my security deposit. [Linked Image]
#121930 09/02/05 07:59 PM
e57 Offline
Do this all the time... Important not to use screw gun! And, solid backing at the opening. I usually write on the wall for the glass guys to add mastic all around the box. It helps reduce the chances it will crack.
#121931 09/03/05 05:02 AM
It wouldnt be allowed in that room in the first place in the uk, so I guess we wouldnt have the problem with the mirror, uk 240v and outlet+wet hands dont go together to well
#121932 09/03/05 09:52 AM
Anyone else think the plate screws should be stainless as well?
They appear to be ivory.
I may be mistaken but isn't that 240 system still 120 volts to ground, presenting the same level of danger to the user?
Interestingly if this was a 240 outlet the NEC would not require GFCI protection.
#121933 09/03/05 11:16 AM
We always used mirror plates for this, not stainless.
Ryan Jackson,
Salt Lake City
