216
11
Even dumber than the Cow, is the guy who was trying free it.
"Veal?"
The cow looks a little old for veal. Defineatly prime rib though!
Larry, LOL , Alan
Look at the ground. It really appears to be worn. Renosteinke, you are probably correct.
This isn't the first time a cow has been in this position. Can the PoCo bill the farmer for use of their equipment???
RSLater, RSmike
Never mind. My comment was worng.
[This message has been edited by jdevlin (edited 09-08-2005).]
My guess is while the cow was scratching it’s head it passed through the first two columns. Scared by having it’s head stuck in the middle of the fore columns and having a brain the size of an orange, Bessie we will call her decided to try to walk through the structure. By the pile of patties I would say Bessie was there for about three days. The blue stuff, I’m sure is a salve or coagulant. And I’m sure the rancher was only going to unbolt the two cross braces so he/she could push Bessie’s head up an out. As for the angle grinder, looks to me like a can of what ever the blue is and a lead rope.
Welcome to the Forum, D-D. I think you're right about the angle grinder. Also, a closer inspection reveals it's a Little Heifer.... ( It helps if you say this with a Dick van Dyke 'Mary Poppins' accent.) Alan
Nope, I go with the theory of it being deliberate. Look at the 3rd picture. There is a big pile of dung there larger than what could be attributed to that single cow. More than one cow had been in that exact same position, and quite often. Rancher probably took the picture. That is his wrench on the ground, and he uses the top cross piece as the "lock".
JRaef
As someone involved in pursuits agrarian I shall shed some light here:
1) It's definately NOT delibrate. So how do I know?: Any rancher who pays to have round bales wrapped in plastic (white things in the distance - photo 3) has a chute with a head gate at the end of it - that stuff is expensive and it shows they care for the nutritional value of the hay in which case they care about their animals. It's a beef animal (could be a heifer - but most likley it's a cow) so therefore it's unlikely to have the close tame and trusting nature a dairy cow would have to enable YOU to get her head in there voluntarily. Even with her head in that "gate" you still can't work on her - legs kick. She is currently worth anout $1000 give or take - why put her in a device that would allow her to break her neck when she panicks. Head gates restrain but they also protect the animal from injury. The angle iron on the pylon makes for a very sharp cutting point - just apply 1400lbs of weight. The obvious salve (antiseptic wound type) demonstrates that rancher cares about the fate of his/her animal, it's not a lubricant - her head would have been doused in mineral oil (readily avail. on most ranches) for that. She hasn't been there that long (max less than 12 hours) - pile of manure is not nearly big enough.
In anycase she has followed the basic law all animals follow - if what they do suprises you, you underestimated what mischief they can get up to, in which case you are dummer than they are.
Dont know if they could get her out (possibility of unbolting some of the struts) but if she was destroyed there is a good possibility the POCO would have to foot her replacement bill (their product did the damage). In anycase she is probably insured.
Anyway thought you might like a little farming perspective.
