390
14
Posts: 3,682 Likes: 3
Administrator Member
Reason # 271 Why I Hate PVC
-John
Ok, let me play devil's advocate.
Yeah, it's ugly, but I don't see any code violations other than the lack of expansion couplings. That would explain the separation.
Furthermore, if there was a problem with the underground feeders, this may well have been an emergency fix done in a hurry to get the power back on.
I look at this and say "What's the big deal?"
Peter
Peter
I get the feeling that the roof is newer than the wacky run. I may have been straighter before the roofers pulled it to one side for thier work, and never put it back. The other stuff on the roof being a bit more rigid, they just lifted up, splid new roofing under, and put it back down. The very slinky PVC they just dragged around, after all, whats it gonna do? Leak?
I will eventualy fail, that guys just hoping its after he retires.
e57 is correct. The roof is newer than the PVC installation. CT is also correct. The PVC "repair" was an emergency installation when the UF failed. Bill
Judging from the corrosion on the straps, that "emergency" repair has been there a long time.
I don't think you can blame the PVC itself -- a properly cemented joint is as strong as the base material. (It says here on this can...)
It looks like maybe the S-curve might actually have been intentional, to mitigate the expansion effects. I wonder how much curvature you'd need to eliminate expansion joints? Would the wood sleepers eventually rub their way through the roof?
A good illustration as to why our local code requires exposed conduit on roofs (like this) to have a ground wire....no matter what the material.
