by ale348 - 03/29/24 01:09 AM
by NORCAL - 03/19/24 05:11 PM
Now they're Teaming Up! Electrician/Plumber cooperation at its finest.
Scott, youre getting as good as I used to be at finding strangeness... I can understand a plumber being cool with us and putting a waterline out for us to bond, but I'd think a cap would be favorable to the hosebib on the end... [Linked Image]
THERE HAS TO BE A VIOLATION HERE,PROBABLY A PLUMBING WIOLATION TO HAVE A WATER SPICKET ABOVE ELECTRICAL EQUIPTMENT
JBIELECTRIC EAST MEADOW NY
The hose bibb is there so some poor soul can wash down the switchboard. [Linked Image] [Linked Image]
at least there's a bib on it to stop the grounded electricity from leaking out...and the handle is green indicating a grounded faucet.
Where in the code DOES it indicate size of water pipe necessary to stick your ground...... Something seems funny here.
RSlater,
RSmike
A more serious thought, why couldnt the plumber have used a ball valve and pipe plug? That way some poor fool cant flood the place.
Doesn't it strike you as ironic that the "Type 1 Enclosure" label is directly under the hose bib.
NEMA 3 req. comes to mind!!
There's no minimum or maximum pipe size in NEC 250.52(A)(1) nor is there a material specified, only that it be "metallic".
[Linked Image] The clamp thingamajig is pretty creative, too [Linked Image]
Many inspectors in this area won't accept a capped pipe as part of the Grounding Electrode, because it may contain only trapped air. As lame as this thing looks, it might have been done in response to a correction notice.
Can a plumber put a hose bibb indoors with no drain?
e57 Offline
I think the plumber did this grounding himself after demo of what that ground was connected to. Or, the electrician should have been a plumber.
And they do this, why??--It's the pipe that conducts electricity; water is actually a rather poor conductor. It conducts enough for the few milliamps it takes to kill someone in a bathroom accident, but not enough to seriously be considered as part of the grounding.
In fact, pure distilled water is actually a reasonably good insulator.
