electure...the SE cable is supported securely to the side of the dwelling in the above pictures.The commonly used PVC SE weatherhead only comes with 1 hole for 1 screw at the top.Then I like to use the handy straps to support the cable down the side of the building.
Now when a tree branch comes down on the overhead drop to the house,which pulls the anchor out and the SE pulls off the side of the house with it without much damage (sometimes).
Quick release SE cable supports have been available for years.
I find them desirable...and they are not all done this way.
shortcircuit
