568
36
Sorry can't resist this...
The one of the left is not like the other....
The one of the left is more broke than the one on the right....
Electrical stuff runs on magic smoke. Once it gets out it won't work anymore.....
There, I feel better now. So where's the 'in-use' cover??
Perhaps a few miles of extension cords were plugged into this.
So is there a violation that caused this? Why did the failure get to this point?
RSlater, RSmike
The one of the left is more broke than the one on the right.... Dunno. they need to be washed off
Cliff
Had a co-worker I was doing some work for complain that after he accidentally sprayed his GFCI receptacle, he heard a "frying" noise, then it didn't work anymore. I replaced it, and performed an autopsy... showing him the extra crispy circuitboard. Something about water and electricity
When I remove the 30-amp fuses from people's fuseboxes they say, "We've never had a problem with it".
Dave
I have had this problem before.When my boss only used immitation gfi recepts. Every time we initially put power to them they would make a loud BUZZZ sound then months later we always had callbacks only for the immitation gfi and also ;callbacks about them actually burning up but never the Levitton gfi...but this particular gfi looks aweful close to Levitton so i would only think it was the rain ...Or the ignorance of a in-use cover in the rain..
JBIELECTRIC EAST MEADOW NY
Or or a potential overload condition......
As anal retentive and cheap as I am I purchased four GCFIs, fed them from my load panel, and then fed them to the various branch circuits throughout the house.
The outlets serve as GFCIs for the various branch circuits and are actually handy for plugging in stuff.
It makes it easy to test all the GFCI circuits, I routinely get to see the little green lights (not sure if the lamp is failsafe indication of the GFCI status), and I didn't spend a bunch on GFCI breakers.
Can anyone see any CODE issues with doing this?
RSlater, RSmike
Actually, RSMike, your solution is 'echoed' in the 2005 code, as another way to AFCI protect bedrooms....now, if we can get someone to make an AFCI device.
There is no "real" code issue. The only "issue" is the one that comes from having the gfi remote from the fault; sometimes it can be difficult to find the GFI. Yours being in a central location, near the panel, addresses the issue.
Even where the GFCI circuit has to be dedicated to a particular room (bathrooms and kitchens come to mind), I doubt any inspector would raise an objection.
A dummy GFCI without a receptical might be more apropriate however for bathroom and kitchen circuts... Wouldnt want to accidentally make that SA circut accesable outside of the kitchen now would you?
