527
13
You never know what you might come across. I wouldn't want to be some poor soul on the other end of this. Don't take anything for granted. Submitted by NORCAL
Posts: 943 Likes: 2
His business card is in the bottom of the panel, but we must protect the identity of the guilty as well as the innocent , another thing that is a problem is a lack of circuit directories in the panels.
I like the old saying, "The names are not changed (or are posted in this case) because God protects the innocent" Roger
OUCH!!!
Do we see at least two breakers with green wires tapped off them???
Hopefully they are re-identified at the other end?!?!?!
DIY'er? Or, colorblind person did the wiring?
"Green only as grounding conductor"-what is the code article? 310.12 Conductor Identification (C) Ungrounded Conductors? ("...shall be... clearly distinguishable from grounded and grounding conductors.")
Posts: 943 Likes: 2
I only saw the panel end of that circuit it was done by a GC during a remuddling.
Rollie, There's not a lot of space between the breaker terminals and the Neutral Busbar. Mind you, this picture just proves that those that usually use hammers, shouldn't use screwdrivers.
Why must we protect the identity of the guilty? As a homeowner, I'd like to know who NOT to call. I say post the business card- how else will things change?
Posts: 943 Likes: 2
I do not think the webmaster would look to kindly to doing that.
chimo, I say post the business card- how else will things change? Oh things would change alright!, for the worst. There's all sorts of legal ramifications to doing a thing like that.
Here's another pic from NORCAL showing the path to even get to this panel.
