1 members (Scott35), 590 guests, and 14 robots.
#119199 12/08/04 08:18 PM
This shows how a 110 v receptacle was feed from a 220 pressure tank for a well system.
The 110 receptacle was for a water treatment system. No connectors, and not the color code for the neutral.
At least it was grounded. 20 amp receptacle and a 15 amp plug, no problem.
- Jim M
#119200 12/08/04 08:34 PM
Gee, you'd think that anyone that smart would have just plugged in the 15A plug to the 20A recp. unless twisting the prong is what gives you the additional 5 Amps [Linked Image]
#119201 12/08/04 11:37 PM
the receptacle that the 3 way tap was plugged into was origionally a 240 volt rececptacle. A 120v 20A receptacle has the other prong horizontal.
if guessing that origionally this was hooked up as a 220V outlet for a 220V water treatment system. somewhere down the line, someone installed a new system and rather than wiring properly, they just grounded one leg and twisted one prong so they could fit the plug into the outlet.
#119202 12/08/04 11:51 PM
You're right! It must be that darn dyslexia of mine kicking in again!
#119203 12/09/04 04:22 PM
Hmm,
Gives a new meaning to the term Twist-lock.
This has to be the saddest attempt at modifying a plug, I've seen for a while!.
#119204 12/09/04 04:52 PM
Hey, well the triple-tap only costs a dollar.
No great loss there, huh? [Linked Image]
Trumpy, I've seen Aussie/NZ/Chinese plugs with the pins twisted so that they're parallel (ground pin hack-sawed off) so they could be jammed into American type sockets.
