#119089 11/30/04 06:56 PM
This Gem I found at work the outlet was still being used at the time of the photo but later got replaced. 3 computers were pluged into that outlet and the fourth plug went to a home made 4 way with more computers and whats worse that had another homemade 4 way chained to it with even more computers.
-ComputerWizKid
#119090 11/30/04 10:23 PM
You know it's bad when one of those heavy-duty nylon plugs melts right through!!!!
Hey, those receptacles are not properly attached to the cover-plate! [Linked Image]
#119091 11/30/04 11:30 PM
I've seen that happen many times with those types of male cord ends. For some reason the screws do not seem to maintain their tightness and results in a poor connection and lots of heat if there is much of a load.
Don
