Hi there Guys,
Sorry I haven't responded earlier, but it's hard to use a computer that has no HDD.
Andy, I think everything was hard-wired in here because of the theft factor, but then again I suppose it also prevents kids from poking things into sockets, which removes a certain amount of liability on the part of the moteliers.
Having said that, the TV actually
did have a plug on it, now, which would you sooner steal, the bedside lamp or the TV?.
Kent, BTW, that's my house key for at home here.
Where do you plug in the hot plate?
No need to bring anything like that to these flash digs, WiseOwl, the unit features it's own Free-standing range!.
I was wondering about them breakers myself, there does seem to be a lot of them for such a small unit, but it has it's own Hot Water cylinder, an electric fan heater, a range.
BTW, the Residual Current Device pictured, is actually called an RCBO, meaning that it has a Thermal/Magnetic trip mechanism in it as well, like a normal CB.
Electure, The Breakers are Federal branded, but just above the actual Federal marking on the breakers you can just make out a small 'N', this stands for Nilsen, I'm not sure how these 2 companies became associated.
Paul, These breakers do look a little wierd withe the toggles pointing downward in the on position, as all our other brands of breakers over here, point upward in the on position.
