#118394 09/09/04 08:48 AM
This was formerly the heaviest load in the place, the Coffee Maker! No connector in the handy box, ground removed from the NM, and terminal screws backwards.
Well, that's coming out, let's see where it goes? Splice in the back of the cabinet, to 16/2 SO!
Not in good shape, is it? Many years of cooking on it, as it is the only outlet in the kitchen (Then)
Pulled out the rest and cut it from the #14 K&T circuit, in my newly insulated attic! (Seller insulated for required “energy compliance”. More like fire hazard creation, spent 2 ½ hours up there just cutting things out, as I tracked all the wiring down. Now I’m looking to track down the Insulation Contractor, for skipping the required Electrical Inspection before he did the job.
Another long week of doing things around the house.
Mark Heller (e57)
[This message has been edited by electure (edited 09-09-2004).]
#118395 09/09/04 01:57 PM
Don't worry - even though this is your place we won't accuse you of being a DIY'r [Linked Image]
#118396 09/09/04 05:17 PM
Mark,
I guess that's an upgrade from the 18-2 you found in the garage.
Dave
#118397 09/09/04 05:50 PM
Mark
another non paying job [Linked Image]
Pierre
Pierre Belarge
