#11817 07/24/02 03:15 AM
Plymzx Offline OP
I have puchased a comercial grade deep fryer with two small 115v, .75amp motors that requires a 120v, 4amp powersource. What is required to convert my 110 outlets in my home to 120v, 4amp outlets?
One more question, I need a recomendation on a generator to power this epuipment, uninterupted for 3 hrs. straight.
Thank You,
Todd
Nothing.
120V is a nominal voltage expected to fluxuate as much as 10% either way.
The receptacles in your home are either 15A or 20A and have plenty of ampacity to handle 4A.
Or...
A buck-n-boost transformer would do the trick, and one could use 5A cartridge fuses to come within 120% of the OCPD rating...
Another DIY liability concern?
[This message has been edited by sparky66wv (edited 07-24-2002).]
-Virgil
5 Star Inspections
Member IAEI
Todd,
I think you may be confused with something here. Perhaps the manufacturer of the unit may be able to clear things up a bit for you.
