by NORCAL - 03/19/24 05:11 PM
1 members (Scott35), 297 guests, and 18 robots.
#117487 06/18/04 02:31 PM
iwire Offline OP
I just came back from a work trip to NJ. We went to nine supermarkets and in each one I saw this same installation.
This controlled water flow to a sprinkler on the roof that would be activated by temperature to aid the cooling of the refrigeration condensers.
I did not have my camera with me when I saw the worst one with 24" of free air THHN.
Besides the obvious lack of protection for the conductors apparently the person installing these did not know plain gray 4" sq. switch covers are available, all the ones I saw where these oil burner covers.
Anyone think the plumber did the wiring? [Linked Image]
#117488 06/18/04 04:31 PM
Maybe the plumber/electrician/whoever wanted the red coloring and writing "EMERGENCY SWITCH" on the cover. Thats still not a good enough excuse, because you can get plates made up to say whatever you like, or make them yourself with a plain steel cover and a can of Krylon. Also, does anyone else think the "Sharpie" writing on the cover is kind of hard to read?
edited to add question about sharpie
[This message has been edited by sparked (edited 06-18-2004).]
#117489 06/20/04 12:41 AM
He forgot the comma after the word "roof." It's just to tell you where the wires go.
#117490 07/07/04 07:11 AM
Isn't that the new "Invisi-duit"? It lets you inspect the wires while it protects!
#117491 07/07/04 03:09 PM
Bob:
Could the store be SR??? They are notorious for stuff like this. Usually the 'in-house' jack of all trades maintenance guys.
Had one a while ago, they used good old 16 ga orange ext cords, canibalized the female caps, and stuck THHN thru the holes in the male plug to splice onto a conv. outlet that was all busted up, on the roof.
#117492 07/09/04 12:30 AM
I take it that's not power-limited low-voltage control wiring?
