This troubleshoot took a little longer than most! Customer had some living room outlets that were dead.... checked all the boxes & found electrical anarchy everywhere I went! [Linked Image] yet didn't actually find the fault until I pulled out the tone tracer & lost signal above the fireplace mantle... opened the wall & found that mice or something chewed the romex & it had melted together! (& the breaker never tripped! [Linked Image] ) The rest of the stuff just needs to go!
The riser pic is another one where So Cal Edison attached to a plumbing vent after a tree fell & left their riser kinked & at a 45° angle! [Linked Image] in 1978!!!!
Enjoy!
Randy
Good Grief Randy!,
I've seen some badly deteriorated wiring in my time, but that lot really takes the cake.
Opening the wall is a bit of an understatement, Randy!. [Linked Image]
That riser pic is a shocker, it's a woder the cables haven't faulted since.
And you'd think they could have at least come back and fixed things up.
I mean 26 years is a pretty poor turn-around for good service and customer relations.......
BTW, Randy, what is that small twin core wire in the pic, where your hole in the wall next to the fireplace is?.
{Message edited to add last question.}
[This message has been edited by Trumpy (edited 06-15-2004).]
A plastic box with AC cable, that makes for good work. It looks as though whoever installed this knew there was no EGC and tried to alter this with an additional EGC. If this customer was/is an unsuspecting type, than it is a shame that this has existed this long. Unfortunately, it looks as though they may not have too much money and may have suffered through this for a while. They are very lucky to have the result be that Randy got there. It is good for us as well ...we get some good photos [Linked Image]
Pierre
Pierre Belarge
LOL Mike.. the wall was already soft from moisture seepage through cracks arounf the fireplace.. I pushed it a bit & it broke right through! [Linked Image] The twin core is for speakers..
Pierre, Im with you on this stuff being like this for wayyyyy to long! They don't seem to be poor financially, although the HO is on disability right now.. They've lived here since 1966 & the home is paid for.. I'm trying to talk home improvement loan with them to get everything corrected.. Im afraid of what else might be buried in those walls along with the obvious amateur work, so I'm kinda hinting rewire at them!
-Randy
Waddaya mean rewire, Randy? This place has already been rewired! [Linked Image]
Look, they even added extra insulation in the 4-0 box (9th pic) [Linked Image]
LMAO Scott... You wouldn't want those wire to get too cold now would you! [Linked Image] It was only about 150°F in that attic when I took the pics! [Linked Image] You'd know, Pomona isn't known for cool summer temperatures! (This was walking distance from the LA County fairgrounds for all who're familiar with So California)...
-Randy
Let it burn. Yuck!
I guess that's why NYC requires MC cable...rodents...
