yes . that is the map i am talking about the gas pump units and now just stop there for a sec and look at the map and just image it if the ends of the "islands" have raised concrete gaurd[s] like about 24 inches above the ground just right above the classifed area and put a vending machine right top of it and put a repectale on the island post which it is away from the pumping devices .
i will try to figure out how to draw this to get more clear idea how it can happend ,
thanks electure, for providing the map and i can see they haven't change the classifed area at all
merci, marc
