Assumedly it is 480∆ — 208Y?
Yes
Can you post the rated temperature rise?
No I can not.
The stress and details of cutover work during a tightly scheduled outage always drove me nuts.
This
was a tough one, to keep shutdowns to a minimum our work was coordinated with two other electrical contractors.
One contractor was firing up the new POCO 13.8 V double fed switch gear.
A second contractor was handling the 13.8 V feeds and cut over of the second floor tenant that I spoke of.
And then there was us, killing the original feed to the 208 service ad firing up the new 480 service.
Of the 3 electrical contracting companies involved some where union some where not which caused added stress.
In the end all acted professionally which was good because mistakes could kill.
At about 6 AM the contractor handling the POCO work gave me a rotation check and we landed our feeds based on that.
Then 2 hours later when they turned on the power permanently it was
backward AHHHH.
This POCO switchgear work was fed from two 13.8 V circuits and one had been landed backward, so when they tried closing a tie breaker the it would open one of the incoming breakers.
I ended up getting these guys to move the elbows on my new pad mount transformer, all was good after that.
On the second picture from the bottom does the man door have an self-closer on it?
Yes, circumvented by us each day, however that door is now outside the electric room.
Once I had my heavy work done a block wall was installed around this area, coming out between that man door and the switch gear.
If you look at the bottom right of the third picture you can see a 'duct tape'
stripe laid down on the floor indicating where the wall was going.
It ended making an electric room that was much like Exhibit 110.15 in the hand book.
One large double door opposite the switchgear.
Once the walls went up a fire rated ceiling was installed along with an exhaust fan to the outside.
[This message has been edited by iwire (edited 04-13-2004).]
