1 members (Scott35), 524 guests, and 15 robots.
#116562 04/10/04 05:33 PM
OOOOOOkay... where do I begin.... [Linked Image]
Pic #1... Surface mount 50A recept on the floor... Looks a bit aged for a newly rewired house.. Not to mention Range circuits are required to have a separate ground & grounded phase now.. A 4 wire range recept would be required
Pic #2 Cut-In Recept could have been installed a little neater, this is also above a range hood (No cabinet) the 2 wire type HPN "Heater Cord" was installed by the EC to power a metal hood..
Pic #3 Your typical overloaded 4S box, no blank.. Partial credit given for pulling grounds though.. [Linked Image]
Pic #4 Black RMC, EMT coupling, FMC.... seems none of these things match here..
Pic #5 Missing Blank, vague panel descriptions.. "plug?" The "12-2 SE Romex in pic 11 backfeeds into CB's 1&3.. 30 or 50A.. I forget which..
pic #6 thrown in for nostalgia value, bonus points for the 30A fuses...
Pic #7 No support of BX & NM-B cables
Pic #8 I'm not sure where, but this is tied into something else, but that big, prehistoric, 6-3 did have voltage on one leg...
Pic #9, Dangling FMC, neat & clean install? Hmmmmmm.....
Pic #10... Severed BX cable, severed Romex... the romex is hot. [Linked Image]
Pic #10.. 12-2 romex running a house directly from the LADWP lines
Pic #11... I'm calling BigJohn to pull wire through the U-turn FMC [Linked Image] Nope, no strapping in this pic...
Re-Rewire begins Monday, 86ing the 100A for a 200A service first thing. The customer seems to want electric kitchen appliances, A/C, & a pool/jacuzzi in the future.. Not to mention with the panel up, I can call for rough panel inspection, get my meter released & get some "safe" temporary power in this place until we're done... Stay Tuned! [Linked Image]
-Randy
#116563 04/13/04 11:28 PM
SvenNYC: Dibs on the 50-amp surf. mtg. receptacle if it's an EAGLE branded one
It's GE... With about 10 layers of grease for preservation [Linked Image]
[This message has been edited by Lostazhell (edited 04-13-2004).]
#116564 04/19/04 12:03 PM
EUWWW GROSS!!!! [Linked Image]
If you're gonna keep it....you need dish-washing soap. The liquid kind. Lots and LOTS of it. Oh ... and a sotchbrite pad...or three.
#116565 04/19/04 05:26 PM
That would be the main OCPD yer talkin about there.
-Jon
#116566 05/14/04 02:53 AM
Thinking back to this job, when I called for final, my inspector looked at the panel, looked briefly under the house through the entry door & told me.. "You guys know what you're doing.. Here you go!" & signed the job off! I take this as a compliment coming from an inspector, but isn't he kinda putting himself out on a limb by not checking out everything else? This is the only job I've ever had this peticular inspector on...
-Randy
