590
14
Posts: 3,682 Likes: 3
Administrator Member
Found this spider in an electrical meter appears he got stuck inside and jammed the rotation of the meter
-alan bergold
Seen recently in the back of a magazine:
Please send me two dozen of these spiders ASAP! Sounds like a great business opportunity... Mike (mamills)
ThinkGood — Maybe the slightly refined Arachni-Pace system would arouse less suspicion. {The critter just runs around in the opposite direction of the disk, slowing it down.}
So what happens if the disc stops? it does not register any use of electricity any more?
Theres always enough room in the junction box.You just need a bigger hammer
So it seems like you don't need much to stall out the "motor" in the meter.....
If that thing were any more powerful it would have just sucked in the spider, crushed it and kept on running.....
is that for real?? spider stopped it?
i'd never thaught the meter disc has that less power.
The spining disk is much more akin to a meter movement than a motor. It only has to turn the dials andthat, through gear reduction. A little, hard bodied spider could easily stop it from turning.
this spider has definitely been working out!
