#115620 11/20/03 08:51 AM
This box is a (Hubbell) Raco 3.5" "Ceiling Box".
They've been around since the days of knob & tube wiring.
Where would you use this particular box??...S
[This message has been edited by electure (edited 11-20-2003).]
#115621 11/20/03 10:07 AM
See question #11: https://www.electrical-contractor.net/Education/Mike_Holt_Code_Q&A.htm
Substitute 314.16 for 370-16
#115622 11/20/03 05:26 PM
Only on a ceiling fixture or wall sconce with a canopy that meets the wire fill requirements.
[This message has been edited by Gus1999 (edited 11-20-2003).]
#115623 11/20/03 06:39 PM
Well, it's 4.0 cu in-so it's perfect for old fashioned 14-2 Romex with no ground.
#115624 11/20/03 08:06 PM
I've seen lots of these above sinks in bathrooms on residential work.
Seems that darn plumber always vents straight up, and there's almost always a stud right there...S
TG, yes when they enter from a domed fixture.
Now, what about the ground wire in the 14-2 romex?? It doesn't count?
#115625 11/20/03 09:15 PM
Not if you cut it off before it enters the box...who needs a ground for a light fixture anyway?
(NOTE: That was supposed to be sarcasam...)
#115626 11/20/03 09:57 PM
These things always seem to get added onto over time
"You know, I always wanted an outlet there...."
#115627 11/20/03 10:03 PM
Now, let's deduct 1 conductor for the clamps
...S
#115628 11/20/03 10:08 PM
I never use the 3.5" ones and never with clamps.
Ceiling fixture that lands on a joist and sconces that land on a stud.
They are some of the best support for heavier fixtures since the mounting point is centered on the box.
Speedy Petey
#115629 11/22/03 03:48 PM
I've used these before, and reasoned that the Fixture Dome effectively adds volume to the box that can be divided up for conductor fill. It has been a solution for some tough situations.
But ... strictly speaking, 370-16(B)(1)Exception seems to say that the 'domed luminaire' or canopy space can only be used to avoid counting the fixture wires.
