by NORCAL - 03/19/24 05:11 PM
1 members (Scott35), 273 guests, and 13 robots.
#115558 11/11/03 10:32 PM
The "electrician" decided to convert this 2" EMT LB into some type of 2" EMT LB LL 3/4!
Submitted by;
Scott Griffin
Griffin Electric Co., Inc.
Central New York
#115559 11/12/03 08:17 AM
This used to be called "Yankee inginuity" now it is a violation.
#115560 11/12/03 10:32 AM
Extra service charge for a custom installation...
#115561 11/12/03 08:33 PM
I have a question. Does the N.E.C allow splicing in LBs, can it be used as a general purpose junction box?
If yes, then I would call this "use of an LB as a juction box". This would bring up issues of internal box volume and maximum box fill. Removing the cover would probably reveal a code violation in these areas.
If No, then I would call this "modification of electrical equipment".(modifying a 2"LB to a 2"LB,LL3/4")
Does the N.E.C allow modification of electrical equipment without it being re-certified?
#115562 11/12/03 09:18 PM
Crash, an LB(conduit body) can contain splices, but the body can't be modified. The conduit body cubic inch capacity must be marked by the manufacturer in order to splice in it.
Steve
#115563 11/12/03 09:50 PM
How would such a violation be corrected?
I assume a special box is already sold for that type of configuration or a reducing connector? Or do you feed the fat pipe into a junction box first to tap into the thinner pipe and then from the box to the elbow?
If not....how would you go about puting something like this together properly? [Linked Image]
Asking out of curiosity, not that I'm going to actually go out and do this for someone.... [Linked Image]
#115564 11/12/03 10:11 PM
Sven,
i would imagine the conductors would need to be pulled out, and a proper JB installed
#115565 11/12/03 10:11 PM
Sven, a conventional junction box could be used. A tee condulet could also be installed in the horizontal run and the EMT rerouted over to it.
steve
Steve
#115566 11/27/03 01:05 AM
What article of the NEC does that violate? We drill holes in other boxes, etc. If it doesn't overstuff the LB, it doesn't seem like a bad move to me...can somebody educate me on this one?
#115567 01/07/04 06:27 PM
your violation is probably in the UL listing
for the lb. you cannot modify its surface.
