1 members (Scott35), 505 guests, and 14 robots.
#115513 11/08/03 12:34 AM
The story here is an ex-sconse location.
Each of these wires has had the other end tied off H-N-G in the same manner, and taken out of the serving box(s)
so i ask, is this a Proper Burial ?
~Steve aka sparky~
#115514 11/08/03 01:00 AM
A proper burial would be to remove the cables from the building. However in many cases, this is not possible. Shorting the h-n-g together would "make it impossible" for this conductor to be used in any manner. As far as the wire-nuts not being in a J.B., I would tell the electrical inspector that since both ends are shorted, the V and VA are limited to zero, and therefore it is a class 1 or class 2 circiut
#115515 11/08/03 07:17 AM
interesting classification crash...
#115516 11/08/03 07:47 AM
"Ok Mrs. Smith you'll need a demolition crew and a drywall crew than a painter. I will have to remove this abandoned wire from your house. No no it is for your own good." [Linked Image] Just mark both ends and bury it.
