216
11
Posts: 3,682 Likes: 3
Administrator Member
this has nothing to really do with electrical work. This is one of those 4x 12 gluelams used to support heavy loads. Well i had to cut a switch in somewhere below it, found that there wasn't really much holding it, which was noted by the GC, and the kaos began... The way i figure it, if it looks funny, and it's not my trade, it's probably so... Steve(aka sparky)
What was supporting it, 1/2 dozen 16d nails?
Ryan Jackson, Salt Lake City
more on this, i had to take off the piece of plywood below in pix #1 to enter a wire, when i did people took note, and cut the V out of the plywood above. The only thing holding this is just the waferboard above it The GC had a cow....
From the looks of it, I bet it is only holding floor load and a non bearing wall directly above it. That still doesn't make it right though.
[This message has been edited by Ryan_J (edited 11-02-2003).]
It looks as though the supports for the beam are just to the right of the beam, OOPS!! Whats that, measure once - cut twice Pierre
Pierre Belarge
