221
11
Posts: 3,682 Likes: 3
Administrator Member
Yup, it's the world's cheapest T-Switch here, but would you use it? ~Steve aka sparky [This message has been edited by Webmaster (edited 08-12-2003).]
Do you mean with or without PPE?
I was not aware that you could clamp sealtight with a NM connector, and I have been buying the expensive ones all along.... BTW what are the two wires exiting the panel on the bottom left, ground wire?
I have seen these SqD devices and played with them. FWIW, I'm kinda surprised at SqD for offering such a product for isolating generator current from POCO current - it just seems kinda cheesy to me. My personal choice would be a double-throw, center-off safety switch (along with properly fitted connectors to the box, of course). Mike (mamills) [This message has been edited by mamills (edited 08-12-2003).]
This isn't my work fellas, but that $.02 T-switch would most certianly beat my quotes.
This type of pictured circuit-beaker “intelock” is sometimes found in RVs to select between an on-board genset and “shore power.” I am not sure many electric utilities have caught on to this potential death trap. What amazes me is the 2-pole breaker across from a 1-pole breaker—backfeed guaranteed, unless only one pole of the 2-pole breaker is used. On its best day that can’t work without significant hazard to life and property—unless this is a 100% “off-grid” system. {The white left enclosure looks like a Trace inverter accessory—the installation may be for a photovoltaic home-power installation.}
OK how do you guys feel about this one, (maybe someone can enlarge it) Reliance Controls I was thinking about using this in my own house, the mechanism is not flimsy but it removes with the cover. For the average DIYer this could be a problem. Bob [This message has been edited by iwire (edited 08-12-2003).]
Posts: 4,116 Likes: 4
Bob, Here's a 2x version, anything past that gets really distorted. I REALLY don't like the idea of it coming off with the cover. Bill
i concere with the group here, but lack the verbage to convey the sentiment other than 'cheesy'
Bjarney (et all) could you please elaborate??
Sparky: I guess the thing I don't like about it is that the little "either/or" arm (for lack of a better description) looks very flimsy - as a matter of fact, when I was "playing" with one (not installed) I found it rather easy to bend the arm out, allowing both breakers to be closed (not good ). I hope the one I was handling was the exception and not the rule. Mike (mamills) [This message has been edited by mamills (edited 08-12-2003).]
