#114728 06/12/03 04:52 PM
LK
#114729 06/12/03 06:46 PM
The romex without running board? Yes. The emt under the other pipe? No
#114730 06/14/03 10:46 PM
Hey Scott
Could you elaborate on the use/nonuse of NM cable in basements, maybe your post is too broad/vague. Section #'s
Thanks
Pierre
Pierre Belarge
#114731 06/15/03 06:12 AM
2002 NEC
334.15(A) To Follow Surface.
334.30 Securing and Supporting.
#114732 06/15/03 07:15 PM
Without cracking the book on a Sunday eve, you would need to install a running board to staple the wire to, or drill the joists or run the wire tight to the surface.
