#114699 06/10/03 01:40 PM
My friend, the plumber bought a house. One of the big selling points was the "all copper" plumbing. He wasn't that impressed.
This was his laundry circuit.
(This also, was approved by another home inspector)...S
(Electure)
I see how the tab that is supposed to prevent you from inserting a three-pin grounded plug into that female connector was sliced right off...
Why does the jacket on the right-most cable look like it's overheated and burnt? [Linked Image]
But why go to the store and buy a proper receptacle, box, and cover plate when you have this old extension cord handy that you can utilize?! [Linked Image]
Is there even a wirenut holding the ground wires together? It looks as though they're just twisted around each other. (Not that it would have much effect on the washer anyway [Linked Image]).
the home inspector that passed this house obviously was slipped some $$$$$$$$$
It's really cute how the tap on the water line is pointing directly at the burnt spot on the cable [Linked Image]
'They can't see it, we can just put this anywhere!'
I wonder which came first...the extension cord tap or the third piece of romex (anyone wanna guess which one is the "odd man out"?) Too bad a box, a receptacle, and a licensed sparky wasn't a part of this setup.
Now for a little fuzzy logic...in case of fire, the little plastic tubing will melt and extinguish the fire... [Linked Image]
[This message has been edited by mamills (edited 06-12-2003).]
