Definitely an access issue there too with all that junk in front of the panels.
Question for you guys. The original contributor says the local EC doesn't want to work on this stuff.
So what is a customer saddled with such a dog supposed to do? You can't "live with this"..it's an obvious hazard..
If anyone hasn't noticed, the signs on the big gray panel is in spanish: The word "PELIGRO" (Danger) in the red oval and the words "Alto Voltaje" (High Voltage) in the white field below the red oval.
I'm assuming this is not in the United States, right? I thought all such signs here had to be in English or am I mistaken?
Thanks!!
And why is that welder (I assume it's a welder) covered in bird guano?
