0 members (), 373 guests, and 12 robots.
I see this from time to time and it bothers me a bit, but is it a Violation?
Appears to be a metal box cover on a PVC box.
Also, the hinge on the cover operates in the wrong direction.
Not an "in-use" cover?
The manufacturers instructions (not that anybody bothers to read them) more than likely states the orientation of this cover.
(PS: It's probably plactic, as the box)
Why does it matter what direction the spring cover opens?
Must it open so that the ground pin faces the hinge or the two current-carrying pins face the hinge?
An in-use bubble is much neater-looking also. [Linked Image]
TG,
This is not a new installation, or subject to latest codes anyway.
John,
I'm referring to the orientation of the Box and Cover. I suspect it is as weatherproof in this position as any other when it is closed and that may be all that matters. Does anyone Redtag for this?
(ps it is a metal cover)
Sven,
If the cover is oriented in the intended manner it does give some protection from the elements when it is in use. But I think it's only requirement applied to the protection it gave when it was closed.
I have a silly question; Can an in-use cover (which I have seen installed on many vertically-mounted devices) also be used on horizontal as well, or are there in-use covers specifically made for this?
...throw pebbles, please...not big rocks [Linked Image]
Mike,
No pebbles either,
Sure they do, here's one style made by Carlon:
Take a look here for more on them.
Product Catalog >> Electrical >> Weatherproof >> In Use Covers.
[This message has been edited by Bill Addiss (edited 05-05-2003).]
Hi Bill: Thanks for the info. Sure looks like a much nicer install, as well as being able to shed water better.
