1 members (Scott35), 130 guests, and 10 robots.
#114491 04/03/03 09:54 PM
I was up on an aluminum coated roof on a rainy day, after being asked to repair a 277V floodlight that wasn't working. Red Flag was the cord /connector. Opened the cover and Voila!
I'd sure like to find the "electrician" that did this
...Scott (Electure)
#114492 04/03/03 10:19 PM
What looks like a high-performance weep hole begs the question, "Was it ½ full or ½ empty?"
#114493 04/04/03 07:54 AM
Most people don't know that you can increase the ampacity of your conductors if they're water cooled.
#114494 04/04/03 09:44 AM
My concern is more with the unterminated ground wire from the fixture, via the cord.
Scenario:
Some unwary soul goes to troubleshoot this fixture (maybe take a voltage test).
If there was a winding to core short in the ballast (which would have gone on undetected indefinitely without a ground connection)...well, then
What would be the end result???
#114495 04/04/03 11:39 AM
Ah,
I thought you were attacked by insects here.
#114496 04/04/03 12:31 PM
Electure:
Bitten once, know what you mean.
I make it a "habit" to always carry a non-contact voltage detector. I check the fixture housings before I touch them. This is a common problem. "The green wire don't do anything" mentality. 277 volt jolts are not a good thing.
#114497 04/04/03 08:07 PM
HotLine,
Tell me about it!.
Man, this could be really dangerous on a wet Metallic roof.
Some-one needs a damn good kicking, for this one!. [Linked Image]
#114498 04/05/03 05:12 AM
F
hotline1 : try to deal with 480 unground fixures they are my top of worst type of fixure to deal with it especally on wooden post i got "hit " with it before.... and i have a habit to use non concat voltage tester almost everywhere i go now including home area i have work on metel box and somecase have hot and nutureal or ground wire revresed that is spooky i really hate it grrrrrrrrrr
merci marc
