Electricians revenge
1 members (Scott35), 152 guests, and 14 robots.
#114318 02/20/03 03:30 PM
I found this Service Entrance Panel on a farm in Illinois. It was installed by a Plumber, who thought he was an Electrician.
Bill Christensen
#114319 02/20/03 04:58 PM
Numerous code violations not-withstanding, This guy must have spent quite a good deal of time fabricating this "masterpiece" [Linked Image]. There are, of course, 3R panels readily available that are designed to safely serve this particular function, certainly at far less cost.
I guess he gets an "A" for creativity, but not for anything else.
#114320 02/21/03 08:11 AM
Not to defend this, but i'm an electricain who thought to be a plumber at times in my own home.....
btw~ farms are exempt from OSHA i believe...
#114321 02/21/03 06:38 PM
from sparky... farms are exempt from OSHA i believe...
Why is this? They employ also.
[This message has been edited by txsparky (edited 02-21-2003).]
Donnie
#114322 02/21/03 08:33 PM
The upper lefthand breaker looks like one of those fancy “phase adder” units that magically make 3ø from a plain old 2-wire service.
#114323 02/22/03 01:56 PM
Z
When using #14 copper with a 30A breaker it looks like it's a good idea to protect the neutral as well. lol
#114324 02/22/03 06:25 PM
txsparky,
dunno, but the fact that EMS has a dedicated 'Farmedic' course speaks volumes....
#114325 02/23/03 01:45 AM
[Linked Image] now that's spooky!
#114326 02/25/03 03:08 AM
Is it just me or is that four wires (two whites and two bare coppers) going into the bottom left terminal of that silver-coloured block?
It's the one that has the single copper wire coming out the top (next to the fat black wire)
I thought you were only allowed to connect one wire per terminal screw unless specifically listed?
There's also two black wires connected to the bottom of the left-most 30-amp breaker (in the trio at top left).
#114327 02/25/03 02:41 PM
SvenNYC
Both of the added circuit breakers, on the left side, are installed in an enclosure designed only for one.
Yes, the question you ask can be answered by reference to 110.14.
PS: That glow label in the upper left says something about therminations when aluminum is used.
If some one can take a clear picture of this somewhere and post it or send it to me, it includes the instructions related to terminations.
[This message has been edited by Joe Tedesco (edited 02-25-2003).]
