235
27
Posts: 3,682 Likes: 3
Administrator Member
This is in the same building as our office. Someone has put a tag on a piece of equipment warning that it shouldn't be used. He or she also put a padlock on the emergency disconnect. There's just one little problem...
(In case you were wondering, "Nödströmbrytare" means emergency disconnect in Swedish.)
C-H
i wondering if they put the padlock to keep it on all the time i can see the box with handle with lever up to on postion and lock it on all the time to prevent anyone to turn off the power by mistake i see it some in both usa and france locations
P.S. i belive the code do allow to keep it lock for specal reason i dont rember it is fall under section 200 or 450 ( 96code)
merci marc
Frenchie- I believe that whether you can lock the disconnect in the "on" position depends upon whether there is overcurrent protection at, or next to, the disconnect. I see a lot of such "lock-ons" at service entrances, just before the meters/panels.
Posts: 1,498 Likes: 1
