The Electrical Contractor Network
ECN Electrical Forum
Discussion Forums for Electricians, Inspectors and Related Professionals
Books, Tools and Test Equipment for Electrical and Construction Trades
Topic Options
Rate This Topic
#114293 - 02/16/03 10:18 PM Swedish Lock-out Tag-out
Webmaster Offline
Loc: NY, USA
 Quote:
This is in the same building as our office. Someone has put a tag on a piece of equipment warning that it shouldn't be used. He or she also put a padlock on the emergency disconnect. There's just one little problem...
(In case you were wondering, "Nödströmbrytare" means emergency disconnect in Swedish.)
C-H
Top
#114294 - 02/16/03 11:16 PM Re: Swedish Lock-out Tag-out
frenchelectrican Offline
Loc: Wi/ Paris France { France for ...
i wondering if they put the padlock to keep it on all the time i can see the box with handle with lever up to on postion and lock it on all the time to prevent anyone to turn off the power by mistake i see it some in both usa and france locations
P.S. i belive the code do allow to keep it lock for specal reason i dont rember it is fall under section 200 or 450 ( 96code)
merci marc
_________________________
Top
#114295 - 02/18/03 05:02 PM Re: Swedish Lock-out Tag-out
John Steinke Offline
Loc: Reno,Nv., USA
Frenchie- I believe that whether you can lock the disconnect in the "on" position depends upon whether there is overcurrent protection at, or next to, the disconnect. I see a lot of such "lock-ons" at service entrances, just before the meters/panels.
Top
#114296 - 02/19/03 12:29 PM Re: Swedish Lock-out Tag-out
C-H Offline
Loc: Stockholm, Sweden
Well, I'm certain this wasn't intended as a lock-in. The trolley hoist (Is that the right word? It's used to lift cargo and move it along a rail) it controls has been hit by trucks repetedly, which has meant that the rail is severly damaged. Someone inspected it a few months ago and decided that it shouldn't be used. When I saw that someone had put a lock on it I thought "Great", but a moment later went
Top
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
