#114283 02/17/03 01:05 AM
Was this done by an electrician? Don't think so!
Very high traffic-public area on Pacific Coast Highway in So. CA.
120V "Ropelights"
-Electure
#114284 02/17/03 12:28 PM
Well at least they tried :-) Most of the time I just see tree lights plugged into regular indoor extensions dangling from one tree to the next...
#114285 02/17/03 10:43 PM
Z
Looks like a black freaking garden hose feeding that box on the tree..
#114286 02/17/03 11:10 PM
Scott (electure),
Is this near Newport Pier???
Looks kind of familiar - maybe Huntington or Seal Beach Pier area???
Scott35 S.E.T.
#114287 02/18/03 07:59 PM
Everything on the tree looks OK- metal (look at the screw indents) outside cover, used a junction box, attempt at strain relief. What strikes me is that the connector under the box looks like a plumbing PVC piece, and the conduit appears to be drip irrigation tubing. The curve in the tubing make me doubt that it's buried mor than a few inches deep.
Also: If he'd used a plastic outdoor box, he wouldn't need a ground wire.
#114288 02/20/03 12:18 AM
Scott...newport pier was torn down years ago, you are probabley thingking of Huntington pier. [Linked Image]
#114289 02/21/03 09:02 AM
Boy, you guys have got some sharp eyes!!
Yes, it's across from HB pier.
The white PVC fitting is an irrigation transition fitting to adapt from PVC to the 1/2" poly irrigation tubing that was used here.
Ground wire? What ground wire? Zip Cord runs through the "conduit"!!
(BTW, in the early 70's I lived in a house next door to this location. Built in 1908, 2 story, and rent was $125 a month. The City bought the property and razed the house.
It's now occupied by condos...about $500K for 800-900 sq ft. There goes the neighborhood [Linked Image])
[This message has been edited by electure (edited 02-21-2003).]
#114290 04/12/03 11:04 PM
Z
I grew up in Huntington Beach...you should have seen the old main street, before they tore down the Golden Bear. It made this look textbook...
#114291 04/15/03 07:53 AM
Zapped,
This is on the exact location of the old Golden Bear!
#114292 04/18/03 09:16 PM
Z
I know exactly where that is...I used to work for a company that performed all the electrical maintenance on the Edwards Cinema upstairs. If I only had a digital camera back then, I'd be posting here daily...
HB, Bro!
