1 members (ale348),
302
14
Posts: 3,682 Likes: 3
Administrator Member
Fun with Foam? More Foam My ceiling fan don't work? Pulled fan down, no screwdriver needed. held up by 2 little screws attatched to the lath . 3 inch piece of romex sticking out of somebodies masterpiece of a plaster job. After chipping away plaster found another masterpiece. Newest version of a weather proof box? - Ron F
on the foam, there are 'energy seminars' where this is pushed, the exact application not clearly understood.....
Posts: 7,381 Likes: 7
Now those are some real works of art. Handyman, DIY, or Sparky wanabe??
It's time for a real EC... John
the problem is, many think this is perfectly fine.
after all......it works!
Scott Actually these area a few pictures from what started out to be a service call to repair a few minor violations that a homeowner had. Turned out the towns building departments electrical,fire inspectors were already involved. This was a 2 family house, the basement alone had 29 j-boxes with everything from knob and tube, stranded wire and zip cord coming out with floating spices outside the boxes. these fed the 2 upper floors and a detatched garage 75 ft away. End result was house red taged tenants removed. 100% rewire and new service
100% rewire and new service Thank goodness!!
Peter
Come on guys! The homeowner just finished reading the following article from the Jan/Feb 2003 This Old House magazine:
Once again a reason why I HATE FOAM!!!!!! That stuff is awful, poisonous and of absolutely no use. Windows fastened with foam will in case of a fire just fall out into the street and vent the room even better. Some months ago a fllor guy tried to jack our floor with that stuff (didn't have our permission to do that). Result was: Floor didn'T sag any more but protruded 1/4". And green foam came up through the gaps of the red oak boards. Floor guy: "But you won't see this after you sand the floor!". -> Rip everything out and redo the floor properly. AAAARGHHHH!
Ron, Good. In the original post you say "my fan" so I assumed that this was in a house that you had just moved into.
You know what happens when you ass u me.
Scott
