1 members (Scott35), 225 guests, and 10 robots.
#11345 07/10/02 08:17 PM
ayrton Offline OP
I am pricing out a fire alarm system for a sprinklered building. Where can I find out the info needed for the requirements?
#11346 07/10/02 08:53 PM
Ron Offline
Your applicable building code and NFPA 72.
Many local fire alarm vendors will lay one out for you.
Ron
#11347 07/11/02 11:02 PM
ayrton,
If your company isn't certified to install fire alarm, I would sub it out to someone who is certified. Your company can install all the conduit stubs in the walls for the "pulls", "strobes", "audio/visual strobes", boxes for the "smokes", etc. Good luck.
Earth, Wind, and Fire Alarms,
Doc
The Watt Doctor
Altura Cogen
Channelview, TX
#11348 07/13/02 05:45 PM
Good advice from the doctor!
This is standard procedure for us for commercial construction. The only time I'll touch any F/A equipment is if it's something really simple like moving a smoke or pull-station.
GJ
Additional benefit is that you will know your exact cost going for F/A for bidding.
[This message has been edited by golf junkie (edited 07-13-2002).]
#11349 07/14/02 09:23 AM
F
That is exactly what we do. In the area where I live, Simplex Fire Alarm Company is used quite a bit. All of their Technicians are certified.
