1 members (gfretwell),
32
14
Posts: 3,682 Likes: 3
Administrator Member
I nominate this guy for a DARWIN award !
This Excavator operator had more than engine troubles, I saw this while doing a temp service Insp, you see the dark area on the track's? well that's fuel , it was running out of the eng compartment , while the guy was working on it , he said , he had put something there to catch it ! I said what? The battery charger???? The wind was blowing the fuel on the charger . And YES it is plugged in ! and NO it's NOT on a GFCI , and if you can see where the plug from the charger IS plugged in , the cord cap cover (el-cheapo) has slide off and the terminals ARE exposed .
- HV (HIGHVOLTAGE)
a contestant for sure....
Posts: 2,236 Likes: 1
how you say out with a bang, but more like a KABOOOOM!!!
HV, A serv call I did to a Putney Vt. gas station revealed 38v from pump to ground ( I mean THE ground..), self servers were dropping the gas nozzel due to being bit. The pump jockeys ( from the oil co) had changed out the pump, never made up the 3/4" GRC, and had left out the grounding conductor. Although I have written this into the forum(s) a few times, similar scenario's are daily for me here......
here's a lil side note for ya,,,, you see that stake in the background? well,,,,, it marks a 800 amp UG to the building,,,I keep my radio on scanner mode I'm just waiting to hear the call, they wanted to string a temp over this , I told them NO WAY dig the new service first, They are putting in a new 800 and an additional 600 for the new building which will go around this. after I saw this , I'm putting it in writing and sending it to all concerned to CMA HV
Fortunately, it's diesel, not gasoline. An owner-operator-contractor I knew used to clean up his backhoe with gasoline...while whisky-drunk...while smoking a cigar.
Hey High Voltage you sure have yuor hands full up there. I can remember doing work in Mass. And if memory serves me right Air Recievers are supposed to be 12 inches off the ground and they ( inspectors ) check them by rapping the tanks with a hammer looking for weak spots. Hmmm..maybe it just Mass...LOL
here's a lil update , remember I said there was an 800 amp ug here,,, well folks , today i was there and he hit it, lucky for him he just broke the pipes and didn't dammage the wires
HV; Was the 800a. energized yet? Hope not...
[This message has been edited by mamills (edited 04-18-2002).]
