Electricians revenge
0 members (), 164 guests, and 13 robots.
#112890 04/21/03 07:13 PM
Z
Looks about normal to me, see this crap all the time.
#112891 04/21/03 08:21 PM
This situation is certainly bad enough. I hate to think how much worse it will be if that water pipe with the corroded elbow ever lets go. [Linked Image]
#112892 04/21/03 08:44 PM
I,ve seen installations by licensed contractors that didn't look much better."But he was cheaper" It looks like crap and half of it doesn't work but it was cheap!
#112893 04/22/03 09:31 AM
I really like the 220 circ that cuts across the bus, goes to tandem breaker on right side, and it looks a bit tight.
#112894 04/24/03 10:26 AM
Do you see any grounds? The only ones I can make out are splitbolted together at the bottom of the panel (hovering over the panel buss).
SD
It is best for a leader to be both feared and loved. But since this usually cannot be done, it is safer to be feared.
#112895 04/25/03 02:37 PM
See it all the time.
I like the phone wire ground sneaking into the righ of the panel. It's the neatest wire in the entire panel.
