Electricians revenge
1 members (Scott35), 152 guests, and 14 robots.
#112814 09/27/01 12:20 AM
These connections were behind the flush mounted dryer receptacle. They fed 2 240 volt AC receptacles run on the surface in NM-B cables. This is 12-2 NM-B.
This is the receptacle end of the AC outlet fed from the dryer circuit.
This was fed by a 20 amp 12-3 NM-B. The splice was buried without a box behind the sheetrock. It fed 2 duplex receptacles wired with 14-2, one on each circuit.
- Jim M.
#112815 09/27/01 06:01 PM
#112816 09/27/01 08:24 PM
Tom Offline
I think this installer learned his trade here in WV. [Linked Image] [Linked Image]
That translucent receptacle box in the middle picture is kinda cute, what did it start out life as?
[This message has been edited by Tom (edited 09-27-2001).]
#112817 09/27/01 08:47 PM
I like the last picture's grounding conductor termination technique, obviously some engineering went into it's design due to the flexibility needed of a flying splice.
#112818 09/27/01 11:53 PM
This guy could not even figure out his color codes. The 3 wire fed 2 duplex receptacles. Yes he had 2 whites on the device, one was hot.
#112819 09/28/01 01:30 AM
One would almost have to be a pro in order to know what mistakes to make on purpose at this magnitude! (did that make sense?)
Wow!
-Virgil
5 Star Inspections
Member IAEI
#112820 09/28/01 03:05 AM
Different receptacles, different wire connectors, and different color codes, but otherwise it's very similar to a lot of the mess I get to sort out here.
That splice on the ground wires looks all too familiar.
#112821 09/28/01 11:23 PM
Maybe this is caused by drinking your beer warm? LOL
