1 members (Scott35), 147 guests, and 13 robots.
#112647 08/19/01 11:43 AM
3 Guesses who wired this Furnace?
(hint, not an Electrician)
#112648 08/19/01 04:30 PM
1. The mailman?
2. The garbage man?
3. The carpenter?
[This message has been edited by Joe Tedesco (edited 08-19-2001).]
#112649 08/19/01 07:03 PM
Excellent Grounding Continuity though!
-Virgil
5 Star Inspections
Member IAEI
#112650 08/19/01 07:36 PM
Joe,
It was the Plumber!
I thought you were a better guesser than that! [Linked Image]
#112651 08/19/01 08:04 PM
And you DIDN'T get a picture of the bend ??????
#112652 08/19/01 08:27 PM
The handy box has four empty KO's, so there's room for four more cables, right?
-Virgil
5 Star Inspections
Member IAEI
#112653 08/19/01 09:05 PM
Would you reconsider the use of the copper pipe, since it maybe of the type that will comply with rules in Article 680 where "brass or other approved corrosion-resistant metal" is allowed to be used for the wiring methods for some systems.
Search for the term "conduit" and look at the many entries in that Article
#112654 08/21/01 07:54 AM
Even plumbers are required to strap their pipe!
There's only one strap visible in this whole mess!
#112655 08/21/01 08:41 AM
George,
I think the bend was OK,
What I would've liked to check was if the cuts were made with a pipe-cutter and if there was a sharp edge inside.
Joe,
You mean this might be OK?
what about the size itself? This conduit is a bit smaller than our Electrical conduit and doesn't fit in the connectors quite right.
#112656 08/21/01 11:53 AM
Bill:
Naturally, I would not permit the material you show, but would permit the same material if it was equal in the ID and had threads as any of the Table 4, Chapter 9 wiring methods.
