0 members (), 483 guests, and 9 robots.
#112372 06/01/01 09:59 PM
As you can probably tell by now, lack of proper working clearance is one of my pet peeves. Wish I could say that the plumber caused this, but the electrician was the last one in.
#112373 06/06/01 08:39 PM
Tom;
You certainly would not like the chain of convience stores i maintain.
My original service call to one consisted of almost a hour to finally find a sub-panel ( for the fuel submersibles) under a counter, behind a wall of junk.
On further investigation ( other calls) i have found most of the chain wired this way
( and it's not bonded back to the MDP either!)
#112374 06/07/01 05:33 PM
Tom Offline
Sparky,
I've got to tell you that I am constantly amazed that there are so few electrocutions and electrical fires.
Someday, one of those panels buried in a junk pile is going to start a nice toasty fire and maybe they'll let you wire the new building. I know they won't let you move the panel.
#112375 06/08/01 10:11 PM
Every now and then a customer, usually living or working in a very poorly wired enviroment will ask me if it's "safe".
As "safe" is a relative term the answer is not always easy. I have tried handouts, referals, disasterous examples etc, none of which has the effect of touting the local fire department's abilities.
