1 members (Scott35), 449 guests, and 12 robots.
#11222 07/04/02 11:13 AM
jo Offline OP
I have three base board heaters all 240V each one has a dial on the side acting as a t-stat
What the customer would like is for all three to work together with one wall mounted thermostat please explain how you guys would wire this.
Thanks
#11223 07/04/02 11:30 AM
Inside each heater, disconnect the internal thermostat, and connect the incoming power lines directly to the heating element. Leave the overtemp cutout intact!
Feed the 3 heaters through the new thermostat, using a relay or contactor if the combined heater rating exceeds the contact rating of the thermostat.
