1 members (ale348),
302
14
From Ian Papp I have attached a photo I took in a mobile home park. This #14 THHN was ran at least 100' away and plugged into the side of the house. I made sure this was removed and went home with me before some one was killed.
Where's the tornado when we need it...
Ian A.
The "Tornado" is down the block and around the corner and says " CATERPILLAR " on it. A.D
Hey, lets look at the glass half full here. Atleast they have the gfi in a box, AND they used BOTH 6-32 screws to secure it. It could always be worse!
Luke Clarke Electrical Planner for TVA.
The "Tornado" is down the block and around the corner and says " CATERPILLAR " on it. LOL! Ian A.
Posts: 794 Likes: 3
Oh, they forgot the "No Equipment Ground" Sticker...
Trailer parks just seem to be magnetic to bad electrical work.. 99% of the ones I've been through were Zinsco infested, direct buried aluminum conductor jungles set up originally as a stop for those pulling an Airstream to the beach. Now they're loaded beyond all comprehension of the lowest bidders' original installation.. The last one I saw had 12/3 SO cord in underground PVC on a 50A 2pole feeding a trailer (sans grounding of any kind!) I got back in my van and drove away...
Lostazhell: You aren't kidding about that! RV parks are even worse. Total handyman specials. Plumbing parts inter-mixed with electrical, propane "issues" like flex connectors running through walls, sanitary conditions that would make the worst gas station restroom look good, you name it.
I love when you see RV's that have been parked in the same spot for decades, the power cord long-since sun rotted, and many times connected with an adapter to plug into a 5-15 receptacle that is equally deteriorated. Not to mention the open receptacle cover since 1969.
---Ed---
Posts: 984 Likes: 1
Hey; there's no weatherproof cover on that box. Did they at least put a hole in the bottom so the rainwater can drain out???
Ghost307
Posts: 5,445 Likes: 2
It's a romex box, for pete's sake! I defy you to seal one - even with caulk!
