1 members (gfretwell),
32
14
Posts: 5,445 Likes: 2
From Adam, in Sparks, Nv. While on vacation off Cape Hatteras,NC, Adam saw what he thought was an interesting meter placement: A closer view of the meter: Comments, anyone?
Ummmm....this is pretty typical. I see this all around my area on similar summer homes.
Peter
Peter
It seems to me, from the design of the house and the rust on the meter, that this area is often flooded. Indeed, the meter might even be below 'high tide.'
Doesn't that seem wrong? Does the meter reader work from a canoe? Does standing in a few feet of water count as "accessible?
Does the meter reader work from a canoe? LOL!! I'd say this all depends on what the Poco wants. If anything at all, the meter should be on the opposite side of house where the body of water is furthest. In other words, if the lake or ocean is in the backyard, place the meter in the front yard. The last thing we need is for AHJ's requesting a yacht to do their work!
This meter is set to be read on horseback.
Get up to speed!
Tesla
Posts: 869 Likes: 4
Or perhaps scooba or proper diving gear while under water.
Rust on the magnet will certainly slow the meter down, customer unlikely to complain, exept when power fails i guess.
I have seen many installs like this on Matagorda Island here in SE Texas. This one actually looks pretty GOOD by comparison . In periods of common thunderstorms and high winds, the salt spray blows horizontally all over the place. In low flood-prone areas like this, the water will lap against the side of the structures and posts at ground level and easily reach equipment installed that high. I guess the meter-reader could stand on the bumper of his truck to read the meter... Mike (mamills) [This message has been edited by mamills (edited 10-10-2006).]
The only time there's water under that house is during a Cat5 hurricane.
Sheesh.
I agree with Mamills, meters and switchgear around salt water will rust from just the salt air.
In FL the pad mount transformers are submerged in storms and if they are still working after the primary power is restored the POCO doesn't even bother opening them, they just keep moving.
Roger
If the meter dial rusts to a stop but the conductors keep conducting, is the electricity free?
